Results 1 to 10 of 20
Thread: A new project (it doesn't have a name yet)
    Aug 2012
    Just thought I'd say a quick hello as I picked up my first series project yesterday (I thought it was a 3 as it has the wrong grill, but it's got a metal dash and serial number to place it as a late 2a).
    Anyway a couple of pictures (don't be fooled I'm going to have to practice what I learnt on my TAFF evening course before I work on the chassis and firewall) before I start to strip it.
    I'll post in the other series area about the engine as it's nonstandard and I plan on putting an original petrol back in.
    Aug 2012
    Adelaide
    Nice truck! Lots of work for you there. I thought that when they converted to a 186 that they had to move the grill forward... Is the radiator still in it's original position?
    I'd be looking at a 200tdi conversion personally
    Aug 2012
    I don't think it's a 186 - there seems to be plenty of space between the radiator, so may not have been moved.
    cookey is offline Fossicker Gold Subscriber
    Feb 2009
    Chrysler 245.
    Cookey
    Aug 2012
    Adelaide
    Quote Originally Posted by cookey View Post
    Chrysler 245.
    Cookey
    Now I look again, a bit closer, it doesn't look like a 186... saw the colour and 6cyl before and assumed. Never seen a Chrysler 245
    Dec 2009
    Queensland (though occasionally elsewhere)
    Quote Originally Posted by Shakey View Post
    Bloody hell!! You've got a Landy with a Hemi in it!!!! Greatest engine in the known universe! What transmission is behind it??? I did a double-take when I saw the motor to which you'd casually referred as "nonstandard"....
    That being said, as I get older and more stodgy I like seeing Landy engines in Landies, so, unless the aim of your project is particularly different, it's never a bad thing to go back to stock.
    Dec 2009
    P.S. Just read the other posts on this thread. That rocker cover looks suspiciously like it has a black "crinkle" finish. Have a look at the lower left hand side of the block beneath the manifolds, just above the sump. If it says "265" there - that's what you've got: a 265 Hemi (202bhp bog standard). If there is no number on the block, it's a 245. There's a small chance it's a 215 (pretty rare), which would be marked also.
    The black "crinkle" finish rocker cover, by the way, was a factory thing for the standard 265...
    P.P.S. Pick the Valiant enthusiast...
    Aug 2012
    I think its the standard transmission John (this is my first series) it still has the standard gear levers etc. I haven't had a proper chance to get underneath it. It needs new springs and a lot of welding, but then what should I expect for $100
    Anyway, I'll try and see what the engine's like and then evaluate the land rover petrol.
    Aug 2012
    John, with the help from the other other thread it's definitely a 265, possibly out of a pacer, originally with 3 speed manual by the sound of it
    Dec 2009
    That's interesting, mate. While I have heard of Hemis going into Landies with standard transmission, they would have to be very thoughtfully driven. Whether a 245 (165bhp) or a 265, they are much, much more powerful than the standard Land Rover fours, with the potential to shred all sorts of things between the flywheel and the tyres.
