Results 1 to 10 of 25
Thread: What engine (Chrysler) is this?
    Aug 2012
    So just rescued a series 2a from a field and I'm trying to figure out what engine it has (is it a hemi?) (as I want to put an original petrol back (which I have access too).
    Any pointers gratefully received!
    Last edited by p38arover; 20th July 2014 at 03:20 PM. Reason: No asking what it's worth questions in this area
    Avoca Beach
    Valiant 245 or 265.(hemi)
    I think the capacity is printed on the block.
    Regards Philip A
    Feb 2009
    Definitely a Chrysler/Valiant hemi.
    Looks like a 245 to me, the engine number will tell you exactly.
    Cookey
    Brisbane, Inner East.
    Hemi 6. 215-245-265. The engine no is on the pad where the distributor bolts to the block. The engine no. will reveal all. Best petrol engine conversion ever for LR's. Hard on drivelines if you are fond of a lot of throttle.
    URSUSMAJOR
    Jun 2014
    Check the number on the dissy pad. It will start with a D. The number after that will tell you the capacity - 1 for 215, 2 for 245 and 3 for 265.
    If you tell me the whole number, I can even tell you what it was likely put in originally. I'm a bit of a nerd when it comes to Vals...
    Sent from my GT-I9305T using AULRO mobile app
    Aug 2012
    It just has a 33 below the distributor, 2651 the other side, a number starting A36 and another starting 5F. Any of those help?
    Jun 2014
    The number on the dissy pad should look like this.
    The top one has the important bit. The 33 - is the following the d?
    Aug 2012
    Thanks those other numbers were stamped elsewhere. I think it's D343300735
    Jun 2014
    Numbers mean:
    3 - 265
    4 - premium/high performance
    3 - had 3 speed manual in the car it was built for.
    Just out of curiosity - the final character on the top line should be a letter. What is it?
    Aug 2012
    I can barely see. If I had to guess I'd say a B? uploadfromtaptalk1405848198540.jpg
