Results 1 to 10 of 17
Thread: Mig Welders Current Settings
    Aug 2012
    I recently did a TAFF course on welding and now looking to get my own mig welder for the odd bit of chassis repair/etc.
    My budget probably stretches to the youbeaut end of the market so my question was around current settings.
    The machines I have used all had a dial and digital output for the current settings so you could have a wide variety of settings. However the ones I'm looking at tend to have high/low or maybe 4 current settings with a variable speed for the wire.
    Is this going to be good enough or will I run into problems?
    Shepparton
    My MIG is 140amp and only has those settings and I have not had any problem welding on a chassis or thinner material. As taught on your course get some scrap steel the same thickness of your chassi and practice on it trying different settings before tackling the real job.
    What I have started doing was writing on the side of my mig in permanent marker the settings I use for different thickness, and have put a line on the by the the wire feed dial. Then next time setup is alot easier - or write it on the inside panel or on a piece of cardboard and store somewhere close to the MIG.
    Brisbane, Inner East.
    Quote Originally Posted by crash View Post
    You too!
    Play with some different thicknesses of steel until you get a comfortable voltage and speed then write it on something like the top or side of the machine. Remember, these will not be "graven in stone" settings and every time you weld you might find you need to vary a bit. Try gluing bits together until you are hsappy with the settings. Try say, 20mm, 12mm, 10mm, 6mm,3mm, 16 gauge, 20 gauge.
    URSUSMAJOR
    The welder should come with a book that tells you what voltage each combination of settings gives you. Wire speed will determine amps and is dialed in to the set voltage.
    May 2014
    Tamworth NSW
    There is plenty of MIG welding setting charts online. Welding is universal between machines, and pretty basic in principle (voltage, amperage, wire speed, stick out, torch angle, filler material, shielding gas, travel speed). As long as you have a reference point back to the voltage and wire speed (amperage) settings, you have basically won the battle.
    1) Setup your wire feed as you have been shown in TAFE. Do a quick 10s wire feed check to work out your m/min calc (wire feed in cm over 10s x 6, divide by 100cm = m/min). You can then adapt to any chart you want (or make your own in excel!). Do this in conjunction with 'scrap' tests to see what works for you. Spend the time doing some destructive testing where you can (weld it, then bust it apart with a hammer to check weld strength). You will learn a lot this way.
    2) most modern machines worth their coin are 'synergic' meaning most of the settings are pre programmed - it chooses a wire speed for a given voltage. You can amend this generally by a value up or down. Older machines tend to have the 'coarse' adjustment of High/low wire speed, and a voltage setting, which works, but is not ideal.
    What's your budget? What power do you have available to you? What materials do you want to weld? If you have the coin for a you-beaut machine, don't settle for a stepwise adjustment. $2.5K will get you a singe phase pulse mig these days. It will also stretch to a very nice 3 phase machine with all the goodies. All depends what you want to do, and how well you want to do it. You can still pay 15K for a feronius mig that will weld a bottlecap to used dunny paper, but realistically, there is not much use in that jump for the average bloke who doesn't work for the space program.
    St Helena,Melbourne
    4.28 MB
    A Welsh welding course, at TAFF no less .
    I recently bought a 130 amp Cigweld mig and it has the type of settings you have mentioned, i dont expect to be welding 10mm plate but it will do panel gauge up to 6mm which is fine for me.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    justfishing Guest
    Hello,
    You always buy the most expensive one in your budget. I have just built a 7m alloy boat with a 210 amp machine more than enough. It is a nothing wrong with them at all It is called a Skill .....very ideal ......Also Synergic means:
    Synergic Mig welding machines provide incremental current pulses which form small droplets of similar sized molten material on the tip of the Welding wire combined with the other specific relationships necessary for stable wire burn off.
    To quote Toxic_Avenger "2) most modern machines worth their coin are 'synergic' meaning most of the settings are pre programmed - it chooses a wire speed for a given voltage. You can amend this generally by a value up or down. Older machines tend to have the 'coarse' adjustment of High/low wire speed, and a voltage setting, which works, but is not ideal. "
    Anyway I also have a ac-dc tig which I brought from a place in Victoria called Tokentools they sell a 210 synergic here's the link I would recommend they I have had great service from them and a great reputation.
    Synergic Welders New Synergic Mig Welder Welding Machines For Sale Australia
    You might have to fit a 20 amp outlet as it will run better.
    Ian
    Aug 2012
    All I want to do is some chassis repairs on an old series (after a lot of practice) and some tree sliders for the D2, I guess I'll go from there!
    TBH I was thinking under 2-300 for a 150-180 amp machine (sorry I thought you-beaut meant cheap and cheerful!) as it's not going to be used day in day out and probably nothing thicker than 3-5mm steel tops.
    Jul 2010
    Hunter Valley NSW
    MIG Settings Calculator
    Check out this calc and the rest for the site. Awesome info
    May 2014
    Tamworth NSW
    Quote Originally Posted by justfishing View Post
    Synergic machines are an ease of use function. It chooses the welding parameters for you (ie your voltage and wire speed) when you stipulate the voltage (heat) you want in the weld. Generally you just need to dial in the voltage, then do a bit of 'fine tuning' for the job to make it work.
    The hardest part of MIG welding is setting the dials. The rest is point and shoot.
    Obviously it's much harder to tweak the weld parameters when you've got one of 6 settings to work off of on the front of your machine, hence my recommendation against those types of machines.
    If you want to put welding in the hands of the every-man, then it pays to make it easy. The number of customers I've dealt with who complain of a MIG that 'doesn't work' are trying to pump 30V thru .6mm wire with a wire feed of 5m/min is astounding. I'm talking blowing thru a contact tip within a second of arc initiation. Every single one of them learned how to use the MIG 'from a mate'. Not putting Shakey in this category, but if he is a learned man, then he sure will appreciate all the extra 'room to move'.
