21st July 2014, 04:37 PM
Testing Fuel Pump TD5
The other day I thought I came across a section in the nanacom for testing / checking the fuel pump but today I can not seem to find it.
Is there away to check the fuel pump / pressure through nancom and if so where is it located in the nancom?
21st July 2014, 09:11 PM
Its listed in the Outputs section of the TD5 app but only checks the relay. If you look at the ECU wiring diagram it only has a pin for the relay and nothing for the actual pressure.
Reason: Additional info
