Results 1 to 10 of 39
Thread: Automatic Welding Helmet
    Welding Helmets
    I have to a bit of welding in the evenings in my garage which only has very basic lighting. My welding helmet is one of those that is powered by a solar panel that gets its power from the welding arc to darken.
    Up to now I have only used it during daylight where it works fine - auto darkening almost immediately on sparks even before an arc is established.
    However at night in poor light I have noticed that the arc has to be well established for a second or so before it darkens and I get blinded and do a bad weld (thankfully the lens filters out the UV so while I get temporarily blinded, my eyes are not getting burnt by the UV).
    Is there a reason it takes longer to darken when welding at night or am I imagining the problem.
    Oh my welding is crap even when I can see what I am doing
    Feb 2009
    I was having the same problem, welding outside in direct sunlight was great. I then stuck my head in a footwell to put a panel in and had blotches and headaches for days.
    In the end i paid a lot for an adjustable shade mask and adjust it as i go. Hard to find the right setting but a whole lot better than the non-adjustable.
    Have you tried having a lot of workshop lights around?
    Crafers West South Australia
    My BOC (CIG) helmet has a sensitivity setting that gets adjusted occasionally. My previous cheapie got thrown out for precisely the problem you are describing. It drove me mad, I don't usually weld in a brightly lit area.
    Thanks for the information - I guess when out in the sunlight the solar panel is picking this up and is basically ready to go when the welding rod is struck.
    It seems I need a better helmet.
    99.87 MB
    If you're happy to pay through the nose for the helmet.
    I now buy the $20 ones from BOC and change the shade from 11 to 9. Just learn the head flick and you're away.
    Slunnie
    NSW SW Slopes
    I recently replaced my old adjustable cheapie with a new adjustable cheapie. The old one had become slow to respond, the new one works very well.
    There (should) be two adjustments, one for shade (darkness level once on) and also for sensitivity (which should be labelled in mSec) . I Paid about $130- or so for a brand name hat with solar, battery backup and 8-13 shade level and sensitivity adjustable. Was from Hare and Forbes by memory.
    McDisco Guest
    I got mine, which is a Cigweld adjustable, from Total Tools for about $80. It has a delay setting, sensitivity and a darkening setting. Its really good and works in all conditions.
    Angus
    Jul 2011
    Yarrawonga, Vic
    He really should have a hat on in that sun.
