G'day Ean.
The Perenties are a 6x4 (front and middle axle) normally.
Engage CDL and the rear axle drive PTO is also engaged. True 6x6.
Gday All,
Are the 6 wheel army landies a true 6 wheel drive or are they a 4WD with a lazy axle.
Thanks in advance.
Cheers Ean
G'day Ean.
Cheers, BDave.
Replace "You are...!", with "Are you...?"
Army Land Rover Buyers Guide.
buymilitaryvehicles.com
Reunited with RFSV 51 680, 'Sleazy'!!
'00 VeryDisco TD5 Auto,
Nanocom Evo for D2 TD5 and Puma
Gone:RFSV, 51-699, Carryall 48-358.
Weeds, that would account for the additional wear on the intermediate tyres, wouldn't it?
While I have never claimed to be a spanner, and defer to an ex-one, all documents I have refer to CDL/PTO engaged, part time 6x6.
Blknigt?
Cheers, BDave.
A mate of mine has confirmed they are 6x4 until CDL is engaged......
It's not the CDL itself that directs drive to the third axle, but the vacuum switch that engages the CDL also provides vacuum that engages the rear axle. They are separate and have two different vacuum diaphragms, just engaged by the one switch.
It is possible to re-plumb the hoses using a second switch to give separate engagement of the rear axle without the CDL, however, then the rear and mid axles will be in mesh with no differentiation, so only recommended for unsealed roads.
I treated my 6x6 just like my defender, as soon as I hit the dirt I would pull the switch........
If you set it up just to engage the third axle and not CDL is wind up still an issue?? I'm guessing not as I drove mine 300 + km on bitumen with the vacuum switch engage as I busted a front axle.......didn't notice any wind up
