I bought a "rubber" boot floor mat on ebay. It was molded to fit rear cargo area and has sides that prevent spills overflowing. I had a cargo barrier installed and it still sat in ok as it simply raised up a little (not much at all) where it met the barrier. It is sturdy yet flexible. I put my wife's roller/walker in the back and simply run the back wheels over the rear lip without any problems as it simply flexes as the wheel s pass over it. I haven't bothered to cut out access holes to the tie downs but this would be a simple thing to do with a sharp knife. I also bought rubber floor mats as well and they fit quite well but I only use them if I go 4WDing. I had bought them before I took delivery and then the car came with mats installed by the dealer even though I hadn't ordered them
Just make sure you get ones that fit the MY14 - I would presume it's exactly the same as the MY13 etc but it doesn't hurt to check.
Martin
