Page 1 of 9 123 ... LastLast
Results 1 to 10 of 88
Thread: Alternator Failure?
    Oct 2011
    Darwin NT
    Alternator Failure?
    Hi, good evening.
    Whilst driving the car to get our daughter from school the battery light came on, followed by medium strength electrical smell (the one that makes you go what smell is that?). She made it home (8 min round trip) but when I got home to check 20 minuets later she would not start at all. I jumped it from the Yellow top Optima (2nd battery) but upon removal of the leads the engine stalled right away followed by the smell my wife described.
    I think the alternator is shorted out internally or something. The mega fuse is still ok though.
    I have the main battery (12 months old) on charge linked to a big jump battery so that is charging right now with no obvious fault.
    Any ideas people or has this happened to others?
    sheerluck Guest
    You'll find a fair few alternator stories on here and Disco3.
    Don't scrimp on the replacement though.
    NSW SW Slopes
    Quote Originally Posted by tiojeffe View Post
    LR stuffed-up the wiring for the alternator by attaching the B+ cable to the starter motor which needs a 500A fuse which means that a shorting alternator will not blow the fuse, flattening the battery and risking a fire instead.
    Jan 2010
    Edmonton Alberta Canada
    Now I understand - the light goes on!
    Combining the alternator feed and the starter feed has the appearance of an elegant design.
    Thanks to Graeme above, the light goes now on given that I had never before seen a vehicle alternator and starter wiring design where the conductors were common, (except on something where the alternator and starter were the same item.)
    On vehicles I was used to, a thick conductor ran between the battery and starter and a second relatively thin one between the battery and alternator. In the case of the 3, while as I said, appearing to be an elegant looking design, I wondered if there was some major downside.
    I had never thought about fusing of the alternator - that is major, and explains why a bad alternator seems to cause such unusual problems.
    Is it still the same on the D4? I assume so. "Never say you are sorry."
    Land Rover ......
    Oct 2011
    Darwin NT
    Thanks,
    Definitely dead alternator then?
    I charged the battery, put it back in and when the battery terminals were put back on the voltage plummeted. Direct short I take it.
    I have never seen anything like it though. It is the fact there is no fuse huh?
    So is it hard to replace?
    Jan 2010
    fuse probably still good
    Graeme is the expert on this but the 500 amp fuse is probably OK.
    It is so big it does not normally blow but instead allows the battery to be sucked dead as a result of an internal short in the alternator.
    Internal shorts in an alternator are kind of a normal failure mode; a circuit design that allows the battery to be sucked dead is not.
    In other words, as above, I expect the fuse is still good but the alternator, not.
    Dec 2009
    Ranelagh, Tasmania
    The alternator is fairly easy to replace. The only difficult part is removing the viscous fan. You come in from the top behind the radiator.
    A search on here will show up some examples.
    They are pricey buggers though, I paid $430 when I did mine, since then they seem to be closer to $600.
    http://www.aulro.com/afvb/d3-d4-rrs/173434-d3-alternator-replacement.html
    http://www.aulro.com/afvb/d3-d4-rrs/...placement.html
    http://www.disco3.co.uk/forum/topic54774.html
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    NSW SW Slopes
    Same on the 3.0 in the D4! I haven't finished mine's conversion, with a 200A fuse (3.0 alternator rated at 180A) waiting for the separate cable to be installed. The delay is due to the 3.0's top radiator hose having to be removed and that I haven't yet worked out how to remove the top fan shield.
    Ford Aust did a proper job of fitting a separate cable on the 2.7 in the Territory.
    Sep 2013
    Yes why can't an inline fuse be installed at the connection of the cable to the alternator? Seems the logical fix - then again will an internal short blow a 200amp fuse?
    Dec 2012
    Adelaide, SA
    Seems to be a very common fault indeed and they all seem to die in the same way - battery light, smell, whirring noise - mine went at about 160K. 08MY RRS.
    Alternators on other cars I've had seem to last longer:
    -my Pintara TRX is on to its third alternator at 435K, the original died at 313K and the replacement I bought from a wrecker lasted until 435K.
    -my missus' Audi B5 A4 1.8T is at 320K on original alternator
    -my Audi B5 S4 is still on its original at 260K
    -my current daily Audi A4's original alt lasted 270K. Now at 300K.
    That said, very easy to job to replace it; the visco fan being a little bit tricky but with a bit of colourful language I've always been able to get it off.
