I have one kit left which can be purchased at the group buy price of $180 plus postage.
Nugget Stuff Isuzu Defender Twin Oil Filter Conversion manifolds were delevoped in conjection with AULRO Forum member Cameron who was wanting to do the conversion on his own truck.
The manifolds give a 60mm spacing to clear the steering rod. CNC machined from high grade aluminium billet, the kit is supplied with all the high tensile rod, bolts, washers, spring washers and nuts required to make the job as straight forward as possible.
The parts required to finish the job are all available new from an Isuzu Parts dealer. Parts required to complete the job, along with your kit are:
1 x Oil Filter Housing - 8941145831 (should be available form Japanese truck wreckers from a 4BE1 and 6BB1)
1 x Oil Pipe - 8941587600 (should be available form Japanese truck wreckers from a 4BE1 and 6BB1)
1 x Oil Filter kit - 8943604181 (Includes both bypass and primary filters)
2 x housing gasket - 8943706700
Depending on the origins of the engine, the procedure requires a 10mm hole to be drilled into the engine block. The truck engines already have this hole drilled, however the factory Isuzu engine Land Rovers use the excavator engine which does not have the hole.
A more detailed procedure can be found on the Group Buy thread in the AULRO Marketplace
First in first serve.
nugget stuff home
nugget
