Results 1 to 10 of 16
Thread: TD5 blowing fuses, help wanted.
    guitarcher Guest
    Defender TD5 2006.
    Indicator and instrument fuses keep blowing and the headlights go out. Only blew the high beam light fuses once but others keep blowing. When the fuses blow there is no power at the fuse. After removing the steering wheel and pulling off the light/indicator/horn switch power is miraculously restored???
    I have fitted a new light/indicator/horn switch and still have the problem.
    After replacing the fuses I might get 10 minutes driving before the fuses blow again. Still have dash lights, tail lights and parkers working.
    Any help greatly appreciated, thanks.
    mattandersonAU Guest
    It does sound like a problem at the switch. Have you replaced the headlight switch as well? Or just the indicator/horn switch?
    guitarcher Guest
    Quote Originally Posted by mattandersonAU View Post
    Thanks for your reply.
    Have not replaced the headlight switch yet. It looks ok with no arcing. When the fuses have blown there is always power across the headlight switch terminals but not at the fuses.
    I've just replaced the indicator and instrument fuses and now everything is working again,.....for a short time no doubt.
    I'd probably replace the headlight switch first off. When mine went, it worked intermittently and popped a fuse on two occasions.
    They have a habit of burning out as the current for the lights is drawn through the switch through bad design.
    If you do replace the switch I would recommend also installing the new wiring loom that includes relays so the current bypasses the switch and goes directly to your lights - should be plenty of info on that around the forum. It's not a difficult or expensive job and worked a treat for me. Also made my headlights a fair bit brighter.
    Oct 2008
    Just curious - When the lights go out are you doing anything - for example does the fuse blow when you turn the lights on?
    Are you Hazard lights working? (The Hazard light relay and switch itself can eb a problem)
    Were you towing a trailer? (Ie trailer wiring can blow fuses.)
    Unfortunately intermittent shorts are a pain the arse to find. I had an issue with blowing fuses for nearly 3 months on my TD5. It turned out to be a rubbing wiring harness on the inner wing near the steering box side of the engine bay. The insulation had rubbed through. But It too miraculously fixed it self when I went to change the fuse.
    You might want to visually follow the wiring harnesses from the lights back to the bulkhead and just see if there are any shiny spots. There are a few places on a TD5 that tend to rub - for example the wiring that runs by the servo booster, that's another place that wore through on mine.
    The best situation you can get into would be if it permanently shorted out. If that happens then wire a 12v light bulb across the fuse contacts. The bulb will limit the current, and will glow whilst it's shorted out. Then you can hop out and wiggle things until the light goes out.
    guitarcher Guest
    Quote Originally Posted by BilboBoggles View Post
    For clarification, it is the instrument fuse that is blowing, after that the lights will not work even tho the light fuses are ok. The indicator fuse is also blowing but not at the same time as the instrument fuse.
    Hazard lights are working as are the tail lights, parker lights and instrument lights.
    The instrument and indicator fuses blow whether the headlights are on or not.
    When the instrument fuse is replaced the headlights work again.
    I can't understand how the instrument fuse is linked with stopping the headlights working.
    I have no trailer wiring.
    The headlight wiring and relays were upgraded several years ago and all still looks good and is well protected.
    Thanks for any further advice.
    I have a wiring diagram for the Defender, but it's over in the shed at the moment, I'll round it up today and have a look at what wires that are common to that fuse.
    Do you have a owners handbook for your Defender, I will need from you conformation of the fuse number as per that manual?
    South Yundreup,WA.
    You may have trailer wiring regardless of a tow hitch, maybe worth looking at often these can arc. I personally have had this issue and look like having it again with blowing fuses for dash lights, tail lights, but do not lose the head lights. Could also be in the wiring harness where the joins are and this can be a PIA as it is actually inside the rear pass side of the chassis.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    guitarcher Guest
    Quote Originally Posted by wrinklearthur View Post
    Hi Arthur,
    Sorry for the late reply, i have been on night shift.
    The instrument fuse is No.15 (5A) , and the indicator fuse is No.21 (10A).
    A sparky at work looked over the wiring diagram with me and we think the instruments are linked through the headlight relay, which he checked out to be ok.
    When resistance is measured at the indicator fuse the value is 0.7 Ohms which equates to 17 Amps current draw which is a bit too much for a 10A fuse
    Unfortunately we didn't get any further to finding the cause.
    What headlight relay
