How do you define better?
The Rangerover is up market compared to the Discovery, which means that it has more luxury and more gadgets. As a general rule, this means that the Rangerover will be more expensive to maintain/repair and less reliable. But that is only a general rule - it all depends on exactly which models you are comparing.
Unfortunately, the P38A is usually considered to be the least desirable (although this will generally be reflected in the price you pay!). This represented a major design change from the Classic, which had been in production a long time, and was replaced by the L322 after a relatively short production run. The problem is not so much that problems are likely, but that when they occur, they are likely to be expensive.
Hope this helps,
