Results 1 to 10 of 11
Thread: FFR Battery Compartments
    Apr 2014
    NNSW
    Has anyone put their FFR battery compartments to custom use after ripping out the batteries?
    If so, what have you done or what ideas have you had to turn it into a more practical space?
    Feb 2013
    Sunshine Coast
    The Wolfs use that area as Jerry can storage - not sure if the aperture is large enough on the Perenties though. It is certainly a secure spot to store liquids if it would work.
    Near Seven Hills, Sydney
    RFSVs and related have a dust and water-sealed porn documents box in the driver's side.
    I would one day like to do similar but to keep my fuel and stove.
    Mar 2014
    Hunter Valley, NSW
    They store mud really well. No mods required.
    If you ever need to replace the seals, "number 47" at Clark Rubber is perfect. Just under 2m (180cm -ish) per battery door.
    Around $12 /m.
    Doesn't stop the mud. Just the rattling.
    Quote Originally Posted by rust View Post
    why did you take the batteries s.out of the ffr?
    What elsedid you pull out?
    You can bolt a basic.50ish litre fuel.tank in there
    LandroverScott Guest
    I bolted a tool box onto the slide out tray, but you need to face it back to front to be able to open the lid fully, otherwise it hits the antenna mount
    Apr 2014
    NNSW
    The battery and radio stuff is out because it's mostly a tow vehicle to pull my boat to the beach. I like the idea of storage but at the same time I can't see myself doing a massive 4x4 trip anytime soon coz I always seem to be spending money on keeping my boat in the water.
    For example, on Friday I had a outboard service. On the way home I blew a bearing on the highway. Life's a beach!!!
    I figure a lighter vehicle should take longer to wreck the brakes.
    If you haven't already and you never intend to use. It pull and sell the alternator and all the harnes along with the distribution box.
    Global_110 Guest
    I plan to install a fixed freezer. It will open using the flap. Batteries to be mounted in allie boxes where the jerry can holders are.
    Feb 2014
    Dave's idea of an extra fuel tank sounds like the way to go.
    Thanks.
    Phil.
