I got all the bits I needed for mine - bearing, gaskets etc from Graham in North Melbourne.
Hello all. OK I am looking to buy a LT230 rebuild kit. Where to buy ? Ashcroft UK and another UK mob have them, but is there any one local that sells a complete kit ?
Cheers Hall
If I were rebuilding a transmission I would go the Ashcroft kit.![]()
There's not much in an LT230. Unless you need gears to replace stuffed ones, everything is available locally - and you can get OEM parts too, and they won't break the bank.
For all new OEM bearings, thrust washers and gaskets only went a couple of hundred dollars, but yes, nothing wrong with going to Ashcrofts either.![]()
So who is this, Graham in North Melbourne. that you speak of?
cheers Hall
Yeah, Mario is close to you. Graham owns an runs British Car Components. Not sure if the link below will work - doing this on my mobile.
www.britcar.com.au/smartstart.htm
