Thread: Copper Slip Compound
    Jan 2013
    Molesworth,Tasmania
    The hernia wont take too much more straining at the spanner , so I've made a New Years resolution (either late or early) to put everything back with a bit of Copper Slip Compound on the threads. I cant find it anywhere - does it go by a brand name?
    cheers,
    D
    Gus67kg Guest
    I use "WURTH" CU800
    Back down the hill.
    May 2010
    melbourne
    I use penrite copper eze. Seems to work well.
    Back down the hill.
    Quote Originally Posted by Dark61 View Post
    cheers,
    D
    Are you twisting it the right way?
    Brisbane, Inner East.
    Loctite Nickel Anti-seize is the duck's nuts. It is compatible with aluminium, and copper is not. Loctite anti-seize has the same torque characteristics as lightly oiled threads.
    URSUSMAJOR
    Jan 2013
    Molesworth,Tasmania
    What prompted it oddly was ,I had trouble with an old temperature sensor - the brother in law (used to eat tyres for breakfast / rims for lunch ) also had trouble to the point of saying "its not meant to come out" - so I didn't feel so bad with my meagre effort.
    thanks for all the advice,
    cheers,
    D
