Results 1 to 6 of 6
Thread: Weighbridges etc
    Jan 2014
    PNG
    Weighbridges etc
    With my new Defender, i would like to weigh it,
    as a virgin, i.e. factory fresh
    tarted up, with various potentially useless accessories
    pregnant, loaded up for a two week trip.
    This is all largely idle academic interest.
    I found the attached list, and while it's probably technically correct, not sure its useful, as most locations do not look public friendly.
    So, recommendations for a Brisbane north-side weighbridge, that can give by axle or by corner weights please.
    And do most people even bother, or want to know ?
    Attached Files Attached Files
    apologies to Socrates
    Clancy MY15 110 Defender
    Back down the hill.
    You won't get individual wheel weights but you can get axle weights. Sims, in Crockford St Northgate or up the street on the other side is Frogs Scrap Metal.
    weighbridge
    I went to my local council tip and they were quite happy to weigh my Jeep total and axles with no charge as I didn't require a print out.
    Mar 2011
    Burpengary, QLD
    Quote Originally Posted by JFD View Post
    That would be my first place to try. My local tip (Narangba) requires you do drive over and stop on the weighbridge. There's also a great big display telling you how much you weigh while you're on it.
    Not sure about how it's done per-axle, but that would be a start.
    Feb 2005
    Quote Originally Posted by TeamFA View Post
    Just drive on and stop before the rear axle comes on to the weight bridge, than drive further on to weight the whole car, than move the front axle off to get rear axle weight.
    Feb 2005
    Quote Originally Posted by AndyG View Post
    I weigh mine regularly......helps when you have a weigh bridge at work.
    Not sure you will get per corner weights, but front/rear axle and complete vehicle weight.
    The last time I weighed in in touring mode with camper trailer I was under GVM however I was 20kg over on the front axle.
    Search for my threads on it, there is at least one maybe two where I have listed my weights.
    Nearly everybody guesses but a weigh bridge is the only way to really know
