Thread: Heater display panel unreadable in daylight
    May 2013
    Bittern Vic
    My P38 heater display panel is unreadable in daylight and night time without using a torch. Is this a common problem ?
    What is the best/ cheapest solution ?
    Where do I get a replacement screen/unit ?
    All help appreciated.
    Aug 2010
    Pakenham
    Quote Originally Posted by ian4002000 View Post
    Before you replace the screen, you might want to check the globes behind the Climate control. There are 5 of them.
    Had a similar issue recently, replaced the globes but found irregularity in the input voltage that was causing the the screen to dim to the point where you couldn't read it, then later come good.
    May 2013
    Bittern Vic
    Thanks most appreciated , I will check the globes and the voltage.
    John Brabyn and I wrote up the procedure here: LCD Backlight Repair
    May 2013
    Bittern Vic
    Thanks it is a very helpful article !
