Results 1 to 10 of 12
Thread: Head gasket Q
    Mornington Peninsula, Victoria
    Head gasket Q
    Just wondering what (if any) are the signs of a HG on it's way out. Cheers.
    St Helena,Melbourne
    4.28 MB
    Depending on where its failing, bubbles in the expansion tank/ rad are usually first signs but usually by then its a forgone conclusion.
    Will be dependent on the engine type as well.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    sheerluck Guest
    Quote Originally Posted by gofish View Post
    A head gasket can "go" in a number of ways.
    It can go between cylinders, between oil and coolant paths, between coolant paths and cylinders, externally from the cylinder......
    So you may get one, many, some or all of the following:
    Pressurising of the coolant header tank.
    Bubbles in the coolant
    Oil in the coolant
    "Mayonnaise" under the oil cap
    Chuffing out of the head
    Oil leaks
    Coolant leaks
    Coolant disappearing
    Power loss
    Oct 2007
    head gasket
    besides the above,you may also get the gurgles behind the dash in the heater matrix indicating gas buildup.
    Trev.
    Jun 2014
    Hawthorn
    Quote Originally Posted by sheerluck View Post
    Do you think that could cause a blowout in a radiator hose maybe?
    sheerluck Guest
    Quote Originally Posted by 3lud13 View Post
    Absolutely.
    Oct 2013
    Living in Mandurah
    So pressurization of the system. Blowing out top radiator hose. then another hose etc. Isn't the radiator cap supposed to prevent over pressurization of the cooling system?
    Jun 2014
    Hawthorn
    Absolutely.
    Well thats a relief as that is the only reason I can come up with that my hose blew despite its age. Headgasket is on my todo list just saving some more coin to do it.
    Quote Originally Posted by 1999td5 View Post
    Thats what I thought too but I have a brand new cap so I guess it doesnt prevent over pressurization
    sheerluck Guest
    A healthy petrol engine can compress it's exhaust gases up to about 180psi. If the head gasket is leaking, the compression will be lower than that , but still considerably more than the 16-20psi that most coolant header tank caps will vent at, and can vent at the same speed as the pressure builds up.
    That extra pressure will look for a way out, a weak spot in a hose, a hose clip, another gasket.....
    Oct 2013
    Living in Mandurah
    thanks Dave
    Put it like that I got it now
