truck cab/130 rear window repair
Regards,
Mike.
 Master
						Supporter
						Master
						SupporterMy 130 single cab is eleven years old and the rear sliding window is in need of an overhaul. The glass channel is going mouldy and starting to fall apart. Has anyone replaced this channel and is there a better aftermarket alternative. Have only found channel suitable for the rear side windows.
 Master
						Master
Regards,
Mike.
 Master
						Master
						The replacement rubber for the ute cab rear window is,
Spectrum Rubber flocked bailey channel 350.360
Can be ordered through Clark Rubber $8/meter
Can be replace without dismantling, just takes patience and if I was to do it again I would use silicon spray to lube the bailey channel to help it slide into place.
'95 Defender 130 Single Cab
HS2.8 TGV Powered
98% of all Land Rovers built are still on the road.
The other 2% made it home.
Cost difference between Britpart and Genuine seals: £2.04. Knowing that your brakes won't fail at any moment: Priceless.
