Results 1 to 2 of 2
Thread: 3 Bolt Power Steering Steering Box - Worth Rebuilding?
    Outer Sydney
    G'day all,
    The steering on my 1984 110 has a lot of play (steering wheel moves from 10 o'clock to 2 o'clock position with no effect). I have tried adjusting the top screw on the power steering box, but it doesn't lessen the backlash. All tie rod ends and arms are tight - no play. I assume the box needs reconditioning? The box has done 480,000km. Is it worth rebuilding the 3 bolt box? I have read that the 4 bolt box is a good replacement, but I'm not interested in spending a lot of money on an old vehicle.
    If it all gets too expensive I'm not fussed ditching the power steering and getting an unassisted unit.
    Thank you,
    Edward
    Jul 2008
    Hi
    4 bolts well bolts straight up with a hole enlargement and different end fittings (main hassle search threads is info around or go to hydraulic workshop)
    Why not source a second hand 4 bolt? Can't be that dear and a working car is always worth much more than a broken one.
    I never bothered rebuilding mine.
    It's worth it, a huge difference to the vehicles steering
    Clive
