Results 1 to 3 of 3
Thread: 2000 4.6 Wire harness w/air inj
    P38Tom Guest
    Would someone be able to help me with a wiring problem I'm having. I can not find anything in RAVE to tell me were these wire go. They look like they mount to the coil pack bracket and it seems like a no brainer. I'm worried about hooking any wires to anything on this truck with expert advice or a service manual. I attached photos for reference. With all the experience your shop has someone is bound to know. The photos are the rear intake area that is near the firewall. One wire that looks like a ground is actually red with no tracer color?
    Blairgowrie, Vic
    Smile RAVE?
    Tom, I reckon it's probably from the coil pack wiring. Red and blue wires, both in shields (so perhaps in a mesh sheath with black outside cover are seen on P14 in Section A1 of the elec manual.
    I seem to remember that they were into a moulded plug, but the component view at the end of the elec manual will give you the correct info.
    HTH
    Pete
    Dizzie, 08 D3 TDV6 SE
    Hi, I suspect that detailed local knowledge about Air Injection is fairly thin on this forum because the system was not required for Australian regs. and so was not fitted to vehicles sold here. No joy in the Electrics Trouble Shooting Manual of RAVE?
