Thread: What's the difference
    May 2014
    Southern Highlands NSW
    - between a Series II and IIA ?
    Narre Warren South
    Some info here Land Rover Series 2 Club
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    May 2008
    Bundaberg Qld
    Model changes in Series Landys (generally) is more a matter of evolution rather than revolution. However a couple that come to mind are the steering arms and vent knobs. I am sure the brains trust will be along shortly.
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    'A'
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    The only difference between the Series 2 and 2a was the introduction of the 2.25 diesel to replace the 2.0. As far as I know, no other changes other than the chassis number suffix happened at the same time.
    Changes, including steering arms from top to bottom and vent knobs changing from screw to lever did not happen at this time, but as pop058 says, changes were gradual. Whenever changes accumulated to what the factory thought were significant enough, the chassis number letter suffix changed. Series 2 had no suffix, when a suffix 'A' was added, the Series became 2a, but it remained 2a as the suffix went up through the alphabet (to 'H' from memory) until the Series 3 replaced the 2a.
    Series 2 only lasted for three years, but Series 2a lasted for ten, so there were a lot more changes in the life of the 2a than during the life of the 2.
    Is this also when the petrol engine changed crankshaft journal diameter?
    Aaron
    JDNSW's Avatar
    Quote Originally Posted by Aaron IIA View Post
    Aaron
    They were related - the petrol engine had some changes to have more common parts with the new diesel, but I do not know that they happened at the same time, although it would have been about the same time.
