23rd August 2014, 04:12 PM
In-cab winch switch help please.
Hi everyone,
I've got my Roo Systems 7hp winch on my D2. I'm in the process of mounting the control box up in the engine bay and mounting an in-out switch and isolator in the cab.
Firstly, I have bought a Ridge Ryder (Supercheap Auto brand) in-out winch rocker switch. It has six pins but my winch controller only has four. The pin readout on the new switch is:
1. Power load 2
2.Power in
3.Power load 1
4. Earth load 2
5. Earth switch
6. Earth Load 1
Now here's the wiring diagram for my old switch:
Can anyone please explain to me how I can make this work properly?
Also, I am putting the isolator in the cab as well. I'm planning on using a starter solenoid or something similar and running the switch for that next to the in-out switch. Saves me having to run battery cables into the cab and also having to open the bonnet every time I want to use the winch, and also stops the small chance of someone mucking about with my winch when I'm not around. Any advice on that would be greatly appreciated.
Many thanks in advance,
Dave.
