Normal rule of thumb is that at reasonable quality levels, 1mb = 1 minute of music. So a 16gb flash drive should get you ~260 hours of music. Increasing the quality will increase the space required.
Hi
I will be recording my music onto a 16GB flash drive to play in my D4.I have several already in use however Ive had mixed results with some albums not being visible to the player.The same flash drive works on other players like in my boat(Jensen unit),but not in my grader(Alpine unit).
Is there a correct way of formatting the USB drive????
Can I record a CD direct to the USB without first copying it to my laptop.
ROUGHLY,how many CDs will fill 16GB as I will copy the more favorite ones first.
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
Quality is paramount Dave with a nice juke box,any idea how to include the space when recording,Im a nuffie in these areas
Andrew
It depends on what software you are using to rip a CD to MP3 (or other sound format of choice). It should give you a choice of recording levels.
That may sound a bit vague, but there are several audio formats, and countless CD ripping apps out there.
If you can say which one you use, I can make it a bit more direct.
I think you might have to format the USB to FAT32. But if some album names appear and others don't on the same USB drive then the problem is not the USB format. And yes you can record directly to a USB drive.
Mp3 music files contain 'metadata' (sometimes called 'tags') as well as the music data itself. Among the metadata is the album name, the track name, the artist name, album cover art etc. If this meta data is missing it will not display the album name etc on your music player.
Whether any metadata is present within the mp3 file will depend on how it was created. If you have created the mp3 file by ripping from your own CDs then chances are the metadata is not present unless the ripping software is smart enough (and you set it up correctly) to go to the internet to find the metadata from various databases out there that exist for this purpose.
For any mp3 track you can see the metadata and edit it yourself with certain software. Mp3Tag is a decent bit of gear for this purpose but there are others around too. With Mp3Tag you can view and edit your metadata and if you find it missing you can use MP3Tag to go to a number of online databases and retrieve the metadata for you provided you can identify the album the track originally came from.
2024 RRS on the road
2011 D4 3.0 in the drive way
1999 D2 V8, in heaven
1984 RRC, in hell
I put all the music on iTunes, create a play list , copy & paste. All sweet
apologies to Socrates
Clancy MY15 110 Defender
When ripping a CD, the metadata is not contained on the CD so it is not copied across
unless
if you use ripping software that goes out on the web to look for that metadata.
If the metadata is missing your music player should still play the music if the player (or you) can find the track. The track names (or album names) just won't be displayed on the list of albums or tracks that is on the usb drive so you think they are not there. Or, they might be displayed as 'unknown album' or 'unknown track' - something like that.
Like I said, if the USB drive shows all tracks on one player but shows no tracks on another player then most likely the USB drive is formated in a format not supported by that player. Most (maybe all) players support FAT32 file format. Some players may not support NTFS format.
If the USB drive shows all tracks on one player but only some tracks on another player then it is probably not the file format of the USB drive that is the problem. In this case, more likely to be something associated with the track tags (track metadata) preventing them from being displayed and so you think they are not there.
If you have created the mp3 tracks yourself from your own CD's and these CD's are fairly old then it is likely your mp3 files contain no metadata because old CD's contained no information to describe the contents of the CD tracks (or the album itself). The only way to get that metadata in this case is to add it manually by typing it in using a mp3 'Tag' editor or the ripping software gets it from an online database. Newer CD's may have information about each track (so called 'CD-Text') which can be included in the mp3 tags when the track is ripped to mp3 but the use of CD-Text is not universal and certainly was not available on older CDs.
1984 RRC, in hell
On my 8gb USB, 893 songs,
7.43 gb space, 3.88 free, so 4mb per song
So you should get. 4000 songs
