Results 1 to 6 of 6
Thread: Faulty glow plugs?
    Mar 2013
    Tasmania
    Faulty glow plugs?
    I have gathered up the entirety of my glow plug collection - amount to about 18 for the 300tdi.
    Using a multimeter set to 20k resistance (from memory) I get a reading of around 0.06 to 0.10 on around 5 of them, the majority of the others flicker a reading for a second then show open circuit and the rest don't change the meter at all.
    Using a 12v car battery, earthing the body of the plug and positive on the top though, none of the glow plugs generate any heat or draw any current at all...
    Am I testing them wrong or area they all buggered?
    Mar 2013
    Tasmania
    Turns out I have 18 faulty glow plugs 8 from 2 running vehicles and another 4 taken from an engine removed from a running vehicle with a head gasket failure.
    I would have thought at least those should have had a good win/lose rate! I will be checking my plugs more often now I think...
    South Yundreup,WA.
    Thats a huge failure rate. Have you had someone else test them to be sure?
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    Mar 2013
    Tasmania
    Quote Originally Posted by CraigE View Post
    2 others! They've been tested many times with various methods.
    Jun 2014
    Hawthorn
    Quote Originally Posted by phibbzy View Post
    Out of curiosity and since my glow plugs are currently out of the vehicle how does one go about testing them
    Mar 2013
    Tasmania
    Quote Originally Posted by 3lud13 View Post
    Easiest way is to run a healthy 12v current through them, positive on the top and ground it to the body (the thread).
    You can also use a multimeter to test the resistance through the plug.
