Results 1 to 10 of 14
Thread: TD5 upgrade???????
    Apr 2014
    Morrisons
    TD5 upgrade???????
    Hi everybody, I was thinking of upgrading the exhaust on my td5, has anyone got any tips on what size or style and if it helps on power and feul .
    Thanks luggy
    Oct 2008
    I just had the following mods done. The result was... Stunning..
    - De EGR
    - De CAT
    - Straight through pipe instead of the middle muffler box
    - Bruce Davis Remap.
    - I have the same sized original exhaust all the way through
    As I said the performance is stunning and it's now way more fun to drive than my new PUMA, which now feels broken in comparison... BUT if anything it's using a little more fuel, mainly because I'm wringing it's neck every time I drive it - My wife manages to get slightly better fuel economy out of it than she used to..
    I think the biggest difference was the remap. I think just doing the exhaust would give a placebo effect, and perhaps a minor difference, but not enough to justify the cost...
    BB you had a TD5 with a Cat? Unusual
    Oct 2008
    I think the Australia EU3 TD5 models post 2003 had a cat in the down pipe just behind the engine. I've got the downpipe sitting in my shed now, just in case I need to re cat it at some stage. I suspect a lot of the performance boost might have been because that cat might not be flowing very well after 250,000 ks...
    Jan 2012
    Just bought a variable geometry turbo for my TD5 together with the bigger intercooler, 3" exhaust and BAS remap the Defender flies.,
    We picked a friends Defender with same moods up from Perth and did 4.8ks in 3 days
    It's such a pleasure to drive.
    Quote Originally Posted by Steve223 View Post
    Slow driver?
    Aug 2014
    Just bought a variable geometry turbo for my TD5 together with the bigger intercooler, 3" exim also in perth aust and BAS remap the Defender flies.,
    Steve what turbo did u end up getting looking at doing this to my defender and how are you controlling the boost..vacuum or pressure actuator. Im also in perth if you got it from a local shop, I've been looking at patrol turbos and some stuff from euro cars trying to find out cheapest easiest option.
    cheers Brian
    Aug 2014
    Also luggy with mine I was just looking at swapping my centre muffler with a hiflow muffler that way it should still keep the drone down and flow a bit better. Also with the cat Its odd mines a 2004 and has no cat so must been after that coz looks very stock to me
    Oct 2008
    Is your 2004 a south african build or uk. I suspect the south african got a cat and the uk did not.
    Aug 2014
    Its td5 110 extreme so at a guess would say south African... see I would have thought it would be uk build with cat cos of stricter emission laws in Europe but this is all just guess work being I've owned a defender less than a month haha
