Not sure on an attachment for the Hi Lift mate.
But do a google on Waratah Post Lifter, they're a solid jigger. Used by a family member on a farm. Not sure who sells them.
 Wizard
						Supporter
						Wizard
						Supporter Hi Lift jack come Star Picket puller
		Hi all
I am trying to find an attachment for a hi lift jack for removing star pickets. I am unable to find anything on E-Bay and very little comes up on google. I am sure there was such a product around some years ago, I remember seeing them advertised in the Trading Post or The Land maybe 20 years ago. I imagin it would be pretty easy to jerry-rig something for a one off, but I have a lot of these things to remove so need something a little more substantial.
Appreciate if anyone here can point me in the right direction?
 Fossicker
						Supporter
						Fossicker
						SupporterNot sure on an attachment for the Hi Lift mate.
Using Tapatalk
Try a short length of chain in a loop, a pin or bolt through a hole in the dropper, chain goes under the pin to the opposite side of the dropper and over the jack lifting foot.
Just jack away to your hearts content.
I did similar with two bottle jacks, yuk, that took some time and bending.
Mike
You could try what nismine01 said, or just buy Davis Starlifter !
Brilliant bit of kit, it's a cant hook, log roller, log support (for saw use) and star picket puller all in one.
It was designed primarily for fencing contractors, the star picket puller works brilliantly.
I used a bit of chain as well for fence stumps. Worked great.
I have a bought steel picket puller back from my sod buster days works a treat.
At work we made our own tool that we use to pull them with a backhoe or loader.It would work equally as well on a high-lift jack.
Its simply a triangle shaped piece of 3/4" plate with the star picket triangle cut out of it with the oxy set,it slides neatly over the picket.On the point of the plate there is a hole drilled where a rated shackel attaches a length of hi-tensile chain.
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
This is very similar to mine.Works a treat.
https://www.toolmart.com.au/hand-tools/12200.html
Andrew
 Wizard
						Supporter
						Wizard
						SupporterThanks all
Some brilliant ideas there. I know about the Davis starlifter and a couple of similar ones. Was just looking at a cheapish solution. Got about three hundred to replace along a creek so they are all in pretty crappy nick. Many are bent from years of floods so will no doubt snap at ground level when I apply some pressure.
Travelrover
Adventure before Dementia
2012 Puma 90 - Black
1999 Td5 110 Ute - White
1996 Tdi 300 Wagon - White
 Master
						Supporter
						Master
						SupporterI use a Crescent 383 gripper with my FEL on my tractor. It grips the star picket and lifts it without bending the picket.
Would work fine with high lift jack
you could do something like this:
Removing Fence Posts « The Anonymous Widower
or scroll down to #34 on this thread:
Winch Recovery - No Trees
