Results 1 to 3 of 3
Thread: Power steering pressure psi
    wmd Guest
    Hi all
    I am looking for some specs on the discovery 2 power steering box operating pressure /flow .
    I am hoping to fit a discovery 2 power steering box in my defender .
    This will give me a bit more clearance with the ls1 and ac pump.
    I know the defender steering box operates at 800/950 psi
    The gm power steering pump operates at 1250/1350psi a and flows 2.5gpm this is a bit high for the defender box but it can be adjusted down.
    So if any one has some specs or general info on this subject I would be grateful for your input .
    Jul 2014
    west of Transylvania
    see attachment
    wmd Guest
    Wow that's just what I needed thanks.
    Any body know whether the disco 2 box is as robust as the defender ?
