Page 1 of 5 123 ... LastLast
Results 1 to 10 of 46
Thread: Is independent suspension that much better than leaf spring?
    May 2013
    Port Melbourne
    I've been looking at camper trailers as many others on this forum. I've been looking at the Cub Spacematic Regal off-road. This is a 945kg camper with a ball weight of approx 100kg. This camper only comes with leaf spring suspension. To get the independent suspension (along with other kit) it's the next model up and an additional $8k.
    We want to take the D3 and a hard floor camper from Melbourne to the Kimberly and travel Gibb River Rd and Tanami.
    What do folks think about a leaf spring suspension trailer on those tracks? Are there any concerns, or is the D3s suspension likely to cause me problems before any camper trailers suspension will?
    May 2006
    Woolgoolga
    To answer your question, no!
    I have had both leaf and independent cub campers, the leaf towed better on road, dirt tracks about the same, off road the independent was slightly better in particular to the slow stuff, but not $8k better
    Jul 2009
    If your worried about the D3's suspension and you have airbag then get one of Gordon's (GOE) air up kits, so you can pump each corner up independently, you will need a separate compressor but chances are you will have one for tyres etc.. Plus add in a diagnostic tool that also clears faults and you should have most everything that can go wrong covered.
    Terry
    D1 V8 (Gone)
    D2a HSE V8 (Gone)
    D3 HSE TDV6 (Unfortunately Gone)
    D4 V8
    May 2013
    Port Melbourne
    Quote Originally Posted by TerryO View Post
    Hi Terry, I've got a diagnostic tool, and I am aware of the GOE kit. It's more the thought of a shock absorber failing that I am referring to. There's a description on one here that's a little sobering.
    North Central Victoria
    I have owned a number of campers with independent, spring and Alko torsion bars. My t-van with independent was better everywhere (dirt, road and off road) compared to either spring or torsion bars sprung trailers. However, I'm not familiar with the cub independent setup and Vern could well be correct that the spring version in the cub range is better. If you step outside the cub brand however, this will not be the case generally in my experience.
    NSW SW Slopes
    Those shocks are ecu-controlled variable rate that endeavour to maximise ride comfort and vehicle control which causes the rates to be adjusted to correct shock fade from excessive heat so don't give any warning of overheating. Just make sure your D3 shocks are in good condition, not on their last legs.
    I think the answer to the original question has to be - it depends.
    It all depends on the implementation. There are good and bad in both types. In theory, independent should be a little better.
    Feb 2005
    not ever having independent but my observations are..........
    independent may be/probably is better on dirt roads when travelling at speed
    I don't see how independent is any better for slow rough stuff as all the pivoting is done at the tow hitch
    on the black stuff, I don't see any advantage between the two
    I think its offered as it the latest trend in suspension and buyer take up th eoption.....although in saying that if I build a new chassis for my camper than it will more than likely have independent air suspension, why, cause I can I suppose and it should match my electric over hydraulic brakes nicely.
    Ellendale Tasmania.
    I don't see the issue in trusting offroad leaf springs, never had an issue, in the 10yrs we've had our camper, only replaced our leafs about 3 years ago, pretty good considering where we go.
    Over the years I've seen a lot of trailers with broken independent suspension, usually broken leaf sprung trailers is due to the age and not heavy enough for the weight of the trailer.
    There's a lot of stress at one point in independent suspension and this is where they normally fail, where the spring, shock and arms meet, at the single point where the stub axle is, this is where I've seen most fail.
    For them to be really strong they need to be very strong here and probably why they are very expensive, I wouldn't touch the AL-KO rubber independent thingies.
    That's my experience, oh and I don't have shockies on my camper, some on here have followed us when towing at speed, no bounce, no sway, just sits behind the car nicely.
    Knowing Cub, I'll garrentee they have either 7 or 8 or 9 leaf, AL-KO offroad rebound leaf springs, basically the best leaf springs on the market, which is what are on our camper.
    Baz.
    Cheers Baz.
    2007 BMW R1200GS
    Feb 2005
    Quote Originally Posted by Redback View Post
    Baz.
    what that's taboo isn't it.........
    I have vehicle component leaf springs without shockies.......I always thought they were the best leafs around, 2nd best will do me
