Results 1 to 10 of 17
Thread: Had a Moment Today
    Free Again Thanks Dan
    Had a Moment Today
    Just had the front springs done on the truck and someone had not adjusted the load leveler for the rear air bags to compensate the height difference .
    Long story short i was informed it would be ok for the day first mistake
    Rewind 4.00 am this morning hop in said truck Drive 4 hours first drop no wuckers
    Half a hour latter second and last drop no probs again . Now because the trailer is low at the front (draw bar) and the trucks rear suspension is low as well The lowest point being the tow frame that supports the ring feeder
    Just below this frame the very lowest point is a welded bracket that supports the air lines
    So i finnish said drop drive very slowly out the drive not noticing that i had snagged the air line bracket on the drive way . Head off on my way 2 ks down the road when said air line wears a hole in it from contact with the bitumen
    End result full trailer brake lock up from 100ks due to loss of air
    Yes luck was on my side and any one else on the road today
    As i was in the middle of nowhere i was very fortunate to have a friendly farmer come along that had some air hose and a welder , A hour latter i was on my way dirty jocks and all
    Oct 2003
    Godwin Beach Qld
    You are a lucky ducky with that soft shoulder it could of been truck and trailer with the greasy side up
    South East Tasmania
    Quote Originally Posted by UncleHo View Post
    X2
    sheerluck Guest
    I'm sure that was a case of "new shorts please"!
    Kingston, Tassie, OZ.
    Good to see you are OK Chris, those cows are typically very inquisitive! Many years back my brother had to set a helo down in a farmers paddock after the chip warning for the gearbox went off, he hurriedly set it down before rotation ceased!
    Next morning came back to find cows swarming around, leaning against it happily rubbing against the fuselage....
    JC
    St Helena,Melbourne
    4.28 MB
    I bit you have matching skids in ya jocks now Chris .
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Back down the hill.
    About $1600-$2000 worth of flatspotted tyres there. As Kev said, lucky you kept the shiny side up.
    I presume when you say load leveler, you're refering to the ride height valve? How much has the front been raised?
    Yep ride height valve
    These springs were only a month old and had sagged big time , Mainly because fridge motor extra 600kgs over the front axle and this truck is always up on its weight
    They are also parabolic springs.
    We have two trucks the same the other had a extra leaf added and has been fine .
    This one would be with out the extra leaf approx 60-70mm lower than the other truck.
    Wheelers Hill, Melbourne
    Dr Vella will be pleased
    Quote Originally Posted by DeeJay View Post
    The mighty Doctor did praise one professional Driver
    So Dave do tell how do you know of said Doctor
