After doing everything, mine turned out to be a blown front shock. Initially I rebuild the swivels, had the front end aligned and wheels balanced, replaced steering damper, replaced drop arm ball joint, replaced steering UJ's and tightened up the PAS box.
Everything got progressively better as they were slightly worn but it wasn't until I swapped out the front shocks/springs that the problem resolved itself.
Check the cheap things 1st!
G
