And I though Ralph only leaned to the right because of the fat bastard in the drivers seat. Hopefully the parabolics I fitted solve the lean as I couldn't find any damage when I pulled them out.
Ian
As noted in another thread, I have spent most of the day replacing the RH front spring on the 2a. This broke the main leaf on Saturday, and I have replaced it with one from a Series 3 that I am gradually reducing to bits. I may replace the other front one later.
As you can see in the picture, the break is about a foot from the axle, on the top leaf. What you can't see (I'll see if I can get a picture later), is that the break, as can be seen by the rust on the face of the fracture, started as a crack about a quarter of the way in from the edge, and on top of the leaf. It occupied about a third of the width and a maximum of about two thirds of the thickness of the leaf, with the remainder parting with a loud bang as I scrambled up a rough, steep hill on one of the tracks on the property. Close examination shows that the incipient crack was possibly visible, being marked by a halo of rust dust.
It may have been like that for quite a long time. The car has for several months had a bit of a lean to the right, that I had been unable to find a cause for - I was looking for a worn bush.
The cause of the failure will have been some form of stress localiser, either a metal defect, or possibly local damage, although this would be expected at one edge of the leaf, so my guess is a manufacturing defect is most likely. Still, I have been running on that spring for almost twenty-five years, and the army for twenty years before that (of course, they may have replaced it).
Ian
1964, S2a SWB "Ralph"
1977, S3 SWB "Smeg" (Gone)
1996 D1 300tdi auto (Gone)
1973 Rangie Classic (Gone)
2012, 110 (Series 12) Puma "The Tardis"
1962 109" Tray Back "Ernie"
1998 D1 300tdi (Dizzy)
2017 Kawasaki Versys 1000
You must now cut down the tallest tree in the forest... With... A HERRING!!!!!
Curious - did the second spring's safety loops prevent anything more serious?
Jordan
