Results 1 to 10 of 13
Thread: Edelbrock Carb Heat Problems?
    Aug 2010
    I have a 4 barrel Edelbrock on top of Edelbrock Performer manifold (RR 3.9l v8) and face the issue of a very very hot carbie that's causing fuel vapor issues - I think.
    The carbie is way to hot to touch and my fuel economy non - existent. The smell of fuel vapors and unburnt (?) fuel is very evident. The engine runs like a dog and I am worried it will cause a hydraulic lock.
    Its booked into a carbie specialist in 2 weeks for surgery, but thought I would ask the experts here for any insights!
    I am advised that a 1/2 inch Bakelite block that lifts the carby will assist, but i struggle to believe that 1/2 inch will be enough.
    Has anyone else experienced this or have any thoughts?
    At Carbie specialist I will check dizzy and coil to see if they too are contributing.
    Thanks in advance....
    St Helena,Melbourne
    4.28 MB
    Cant say i had any heat issues on my RRC when i ran a holley, is the t/stat the correct temp ? You could try making a heat shield from alloy sheet and see if that helps.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Brisbane, Inner East.
    The Bakelite insulator will fix it. Also see if you can arrange a cold air intake if you don't already have one, and a cold air duct from the front of the car to blow outside air over the float bowl. Every little bit helps as the actress said to the bishop.
    URSUSMAJOR
    Jul 2010
    Hunter Valley NSW
    I had the same problem with V8 falcon and the spacer solved the problem.
    Mine was perculating petrol when hot after turning off the engine too.
    You can get 1 inch
    1" Phenolic Bakelite Carburetor Spacer Square Bore 4 Port | eBay
    Jul 2010
    Hunter Valley NSW
    You can get 1 inch
    olbod Guest
    I cant answer your question but can I ask.
    Can you still buy this Edelbrock and carb gear to fit a 3.5 v8I ?
    Ta.
    Quote Originally Posted by olbod View Post
    Ta.
    Get an Edelbrock manifold and a Rochester Quadrajet. A far better carburettor, and readily available from any wrecker.
    URSUSMAJOR
    Avoca Beach
    Aren't you going to be a bit light on for air cleaner clearance with a 1inch spacer?
    I suppose you can do a body lift.
    Regards Philip A
    Kingston, Tassie, OZ.
    Quadrajet is a beautiful carb, the Edelbrock however is a close second/ almost copy.
    I also agree the bakelite spacer should help.
    I had a few issues with warping the top cover on a Quadrajet with an insulator, be very careful how tight it is bolted down IIRC the Edelbrock carb also has 2 of the bolts going through the whole carb down to the manifold.
    Great looking engine/ installation BTW!
    olbod Guest
    Anyone have a part number for the Edelbrock manifold and can you still buy a suitable new Quadrajet carby ?
    Ta.
