I cannot see a reason why a standard Land Rover alloy rim as the Boost should not fit a Salisbury axle with drums, apart from the fact that the studs might be a bit short. I can check as soon as I get home.
I assume you are running standard Land Rover steel rims? There is no reason why you should have to stick to 7.50R16 size (apart from keeping up the tradition
). Wolf rims are a good alternative, but will not give other choices for the tyres you are going to fit.
Keep in mind, though, that the rims you are going to fit should have the correct weight rating for your truck. Discovery I rims are not rated for a Defender 110. They will fit, though, and I doubt the rating will have any practical consequences. In some countries, the lack of appropriate rating will make fitting these illegal, so you better check with the relevant bodies/authorities beforehand.
As for those Chinese tyres, I have never used them and, to be honest, will steer clear of them as long as ever possible. Call me a chicken, but I do doubt they live up to any decent quality requirements. Tyres are an important, but often overlooked and misunderstood, part of any vehicle's safety equipment.
Johannes
There are people who spend all weekend cleaning the car.
And there are people who drive Discovery.
