4th September 2014, 07:42 PM
Fuel injected 2st outboards.
I'm looking for another outboard for my old Cruise Craft. There's a couple of motors, namely a 2003 200 EFI Merc and a 2005 HPDI 175 V Max Yamaha and both showing under 500 hours, that I'm looking at so if anyone can offer any advice as to how these motors stand up to the test of time (They're near 10 years old and the boat only does about 30 engine hours per year) or anything else to be wary of I'd be very grateful.
Thanks,
Anthony.
7th September 2014, 07:01 AM
Outboards
Hi , IMO both are a good outboard. First thing to do is check the compression . As Well as the condition of things like gear oil( no water in the gear case), spark plugs (these can tell you a lot about how the engine has been running).
The amount of corrosion is another tell tail sign on how it has been looked after and serviced. . I have been a marine mechanic for 12 years . When I worked in California I got my hand on a lot of optimax outboards . Brilliant t motor ! The only issues I ever had was with one . It kept on chewing up alternator belts. Turns out at one point it had snapped the bolt securing the alt . Hen the owner removed the pulley to get the dent out of it.unknown to him that they a so well balanced that when he put the pulley back it threw out the harmonics . It kept breaking the bolt chewing the belts. 4 belts and 4 bolts later when he brought it to us it was that plugged up with rubber it had insulated the spark plugs. 20 cans of power tune later and numerous runs on the dyno it was signing like a bird . I only had my hands on then Vmax once so I can't vouch for its reliability but I have never heard of any issues . Both have been around a while . But as every thing second hand it's always a gamble . Cheers josh
7th September 2014, 12:41 PM
Thanks for the advice. I figured the Merc would probably be a good thing. The thing that drew my attention to the Yammy was the price but I've never heard of or seen a HPDI Vmax before so I was a bit wary that they might have been the black sheep of the Yamaha stable.
7th September 2014, 02:36 PM
#4
Outboards
No worries. I like the Yamaha products, their four strokes are good! Good luck with what every you get, service and maintain them and either will give a life time of service
