Hi,
I will detail the wiring that I have. If you check it back as a first step.
The LED indicator has 4 wires.
Red goes through a 5amp fuse and connects to a 12 volt ignition source.
Yellow goes to the fuel pump. Black from the pump goes to earth.
White goes to the VDO guage sender on the tank
Black goes to the other terminal on the sender ( which is a brown wire ) and also to an earth point.
Hope this helps.
  Reply With Quote D4  2.7litre
D4  2.7litre
