Results 1 to 10 of 24
Thread: Squeek,Squeek
    Jul 2014
    Squeek,Squeek
    I have a very loud squeek when I turn the steering wheel clockwise. Sounds like it's coming from the draglink joint on the passenger side. My question is can I change this without removing the whole drag link? Never having done anything like this before is there any traps I should prepare for?
    2000 4.6 HSE Alveston red
    2007 307 xse peugeot
    1974 xj6l jaguar
    Jan 2012
    Bendigo
    I don't think it's possible to change just the ball joint . A very wise decision by Mr Lr.
    Sent from my GT-I9305T using AULRO mobile app
    Jul 2014
    Thanks benji the reason I asked is the other end (drivers) looked new.....oh well I'll replace the whole thing.
    Is it just off and on?
    1974 xj6l jaguar
    Are you really sure it's the drag link???? Could it be a belt squeal when pressure is put on the steering pump? From the photo the boot on the drag link looks to be intact... If it is intact means the ball joint is probably still properly lubricated and functioning...I'd be very surprised it is causing the squeak...
    One way you could check is to put the vehicle front axle up on jack stands, ensure the front wheels have adequate clearance and start the engine. DO NOT TOUCH THE TRANSMISSION SHIFTER!!!
    Move the steering wheel back and forth and listen for the noise...may help to have the bonnet open. Get someone you can trust to move the steering wheel and you stand beside the vehicle and see if you can pinpoint the noise...
    Let us know what you find?
    Jul 2014
    Hodges I have had the wife move the steering wheel while I was under the front with a stethoscope and it is certainly squeeking from that joint the loudest. The others are slight but the top of that ball joint is definitely squeeking.
    1974 xj6l jaguar
    May 2010
    Mindarie, Western Australia
    daf11e
    You could also disconnect the drag link then whist up on axle stands turn the wheels by hand to verify the mouse has gone. Just as a test before forking out the $$.
    Gary
    Jul 2014
    This photo may be better
    1974 xj6l jaguar
    Jul 2014
    Gary I gather you mean to turn as in steering not rotate?
    1974 xj6l jaguar
    May 2010
    Correct.
    Gary
    May 2010
    Just looked at the picture.....it's due for replacing
    Gary
