Page 1 of 27 12311 ... LastLast
Results 1 to 10 of 269
Thread: Are 4WDs too high-tech for the bush?
    South East Tasmania
    On ABC is this short video about it
    IMO it is nothing new about it, we need the County back in production for Australia, Africa and South American countries
    DiscoMick Guest
    I have mixed feelings about this. On the one hand, some computerized or electrical issues do seem to be beyond fixing in the bush although, in a lot of cases, the fault is not the actual unit, but some dodgy connection or so on, which could be fixed if the person knew how to find it.
    On the other hand, there are also a lot of mechanical problems which also can't be fixed in the bush. For example, my shredded timing belt has cracked rockers and bent pistons, which could not be fixed in the bush.
    So I think the real question is not if vehicles are too high-tech to be fixed in the bush, but which systems - mechanical or electrical - are more likely to break down in the bush. I don't know the answer to that one.
    South East Tasmania
    I guess that vehicle preparation and preventative maintenance will help a lot to reduce possibilities of mechanical break down.
    Oct 2006
    canberra
    Don't think it makes much difference there's still so called mechanics out there that think a 300tdi is to complicated
    Jul 2012
    midwest W.A
    When a blown stop light bulb can put a transmission into fault mode, that's too high tech. When a blown suspension actuator necessitates a ride home on a flat bed truck, thats too high tech.
    I'm sure there's a few people on here that have heard the story of a guy carving a big end bearing for his engine out of a bit of wood to get himself to where he was going; that's not high tech
    We wont be allowed to go off road soon, so it may become a moot point
    East-South-East Girt-By-Sea
    1.20 MB
    Quote Originally Posted by Gerokent View Post
    Have you ever heard of private property?
    There are remarkably few areas of wilderness in the UK for "going bush" but they still find places.
    Jul 2013
    I get to see a lot of live data that's output from haul trucks for work. The trucks do more running hours than most peoples cars easily, and they have just as much high tech computers etc running around them nowadays compared to cars. Sure they don't have all the safety tech, but the engine management and electrical managment in the electric drive trucks is very similar. For the constant vibrations that they are exposed to there's very little in the way of "computer issues". The most common faults are faulty sensors, fault connections and cable rubs creating shorts or open circuits. Some of these faults you could put down to things not being done right after maintenance, which happens every 500hrs or so (every 20 odd days), someone's a bit rough pulling a connector apart, or cabling not tied up properly etc..Your more likely to have issues after maintenance.
    I think most electrical systems are fairly robust, in saying that some cars seem to have nothing but lots of electrical and mechanical gremlins from day one.
    North Central Victoria
    The only issue I have with my 4 landy's over the years that didn't allow me to get home was a broken water pipe on my 300tdi that resulted in a warped head. I think electronics in 4 wheel drives are great! I love climate control and traction control and love the comfort of my bus on long trips. I have a D2 and a Nanocom and there aren't too many issues I can't resolve myself generally. But all things break down eventually. But proper and preventative maintenance is the key. My D2 hasn't broken down once in 5 years and it's been the most reliable vehicle over ever owned (including a 96 diesel troopy and old diesel hilux). But I am aware of the common d2 issues and maintain it myself including a fair bit of preventative maintenance.
    I'd have a D4 and take it anywhere if I could justify the purchase and maintenance price
    And I'd much prefer to rely on newer technology than an old series or county. In my experience a car that is a few years old is much better in design generally speaking compared to a car designed 40 years ago. (Now preparing to duck to avoid quips from the series brigade)
    Yass NSW
    When a blown stop light bulb can put a transmission into fault mode that's bad design -simple solution, replace the lamp or put in a LED one.
    Height sensors are eaily replaced - it's just a matter of having one. No different to a broken fuel pump diaphram - a broken one will stop you in the bush and there is no way to fix it without parts......
    Regards,
    Tote
    Jul 2012
    Hard to say
    Hard to say if the market or design rule arbitrators would really agree with your sentiment there - at the end of the day that would pretty much drive the decision. Getting a 'new' vehicle of almost 35 years of design age and safety standard onto the roads of the continents (and sub-continent) listed there might be a challenge.
    Most of the major changes in the older trucks came about as a result of mandated safety rules. For example, I believe the Series Land Rovers went 'wide headlight' in the early 70's to meet the German safety design rules and ditto the padded dashes and relocation of the instruments in the Series 3 - if the Germans hadn't asked for it the North Americans certainly would have. Sales of new Defenders stopped in the USA market because they simply couldn't meet the basic safety rules (airbags etc) and the cost of the re-engineering required was judged to be unviable. Clearly Tata is still making that judgement on a global basis.
    The argument that vehicles like the early County-Defenders (90/110) etc are still demanded for utilitarian uses like farm and forestry work etc is also not without challenge. One of the UK Land Rover mags did an interesting comparison a little time ago between a new Defender and a new combine harvester and looked back at the evolutionary path of the two machines. In terms of operator safety, general comfort, noise, work efficiency etc the harvester beat the Defender hands down. Farm and forestry workers aren't necessarily standing at the back of the queue when it comes to demanding these sorts of improvements in their working machines. Semi-trailers seem be another case in point.
    So, I guess it's a case of making a few choices - if you want to take a simple 4WD into the bush just take your old one. Or join the hordes with something newer, quieter, more fuel efficient and safe.
