10th September 2014, 10:47 AM
Algae Fuel Contamination
Put the 2008 110 Puma into the shop after failing to identify and remedy the cause of this issue.
While driving out to the mechanics I noticed a new issue with the idling of the car. Started stalling while waiting at lights, like a fuel shortage.
Upon getting to the garage, we had a look at the fuel filter and it was full of gunk, looked like algae. Cleaned it out and will re-fit and run some fuel through again to see if the contamination is isolated or riddled throughout the tank. If the latter, will have to remove and clean the tank.
I'm conscious of always filling up with premium Caltex Vortex diesel, unless in a remote area and forced to top up.
Anyone else experienced this?
10th September 2014, 03:08 PM
10th September 2014, 04:31 PM
10th September 2014, 06:42 PM
#4
Interesting. I was always taught it was microbial growth. We get this black stuff in jet fuel tanks in aircraft when they are left unused for long periods. Apart from cycling the fuel by using it, we take a hit of fuel system icing inhibitor occasionally. I can only assume it helps separate the water or dissolve the solids (or it's an old wives tale!)
12th September 2014, 03:15 PM
#5
Interesting read LR1979. Got the truck back today. With limited mechanical knowledge – seems I can't learn hard or fast enough – I had to leave it to the blokes at Graeme Cooper. Took the best part of two days to clear the sludge from the tank and hoses – reckon there was over half a litre of the stuff all in all.
As for what it is, they still referred to it as algae. Unfortunately didn't get any pictures, and short of a scientific material analysis I can't accurately say whether it is algal/microbial and/or paraffins and asphaltenes. I have to inspect the filter in 1000kms to check for signs. Will post pics.
At any rate, not a cheap procedure and one I'll be wrapping my head around should I ever need to deal with this problem again.
12th September 2014, 10:00 PM
#6
If it's black and fluffy it's most likely a fungus
Had it in boat diesel tank, and flogged the filters after a few hours It can only grow if there is water in the fuel Used a fungicide called Fireprep 1000
12th September 2014, 10:20 PM
#7
If it's black and gluggy it's most likely a fungus
Had it in boat diesel tank, and clogged the filters after a few hours It can only grow if there is water in the fuel Used a fungicide called Fireprep 1000
15th September 2014, 09:13 AM
#8
Thanks Grappler. Any ideas on preventing water in the fuel tank? I'm about to move the pesky breather in the Puma from up in the wheel arch to the engine bay with a breather kit. Have seen a few auxiliary water trap systems, but am yet to research in detail.
16th September 2014, 09:47 AM
#9
Originally Posted by
MY LANDY
I hope that your fuel problems are all sorted.
I use the PRO-MA DT5 every time I refuel . . . just continuing on with what the previous owner used.
It’s inexpensive insurance for my TD5 fuel system.
The Land Rover specialist that maintains my Defender recommends ‘Fuel Set’.
index.html
