Results 1 to 10 of 11
Thread: Panhard rod e-torx size
    Feb 2013
    Gosford, NSW, Australia
    Hi
    The panhard rods are held on by a Torx head bolt, I think it is an E24 but was wondering if anyone could confirm this.
    A 15/16 socket fits pretty well but given the tension these bolts are under I would hate to round off the head and have to get the bolt out after!
    Steve
    Feb 2012
    Carnegie
    I've removed one using a standard socket. Can't remember whether it was 6 or 12 point though. A good tight fitting socket should work.
    May 2013
    Manly West, Brisbane
    I recently fitted a set of SuperPro bushes so had to remove the panhard rod, a standard 12 point socket will be fine, the bolt should be torqued to 200 NM so it's tight but not blood vessel busting tight.
    Make sure the socket is a good fit though, can't remember the size needed.
    Feb 2012
    Carnegie
    These bolts have thread locker on them as well (blue), as well as the locking ring and the 200Nm. It makes unduing them tough. Try to get as much clearance as you can under the vehicle.
    May 2010
    Mindarie, Western Australia
    When I took mine out I used a standard 12 point socket. Very snug fit and no damage. Just sore muscles at the end of it
    Gary
    Managing in confined spaces, with ageing limbs and tendons, an $80 12V 250Nm electric rattle gun with a torx socket is well worth it!
    Feb 2013
    Quote Originally Posted by Hoges View Post
    I have been slowly buying Ryobi +one 18V gear, looks like it's time for the impact wrench
    Steve
    Jan 2012
    Bendigo
    I couldn't get mine undone for the life of me - Yeh I know. ....
    So I put an extension pipe under the chassis on the driver's side and dropped the car from offroad to access -than did it! Had to use a jack for the rear though.
    Sent from my GT-I9305T using AULRO mobile app
    Feb 2013
    Quote Originally Posted by benji View Post
    My mate Danny has a saving "Let the tools do the talking" .. that's usually when the big breaker bar comes out.
    Sounds like these buggers are going to be fun
    Steve
    Douglas Park, NSW
    Quote Originally Posted by davidsonsm View Post
    I don't know what sort of Loctite they use but it makes the bolt extremely tight to remove all the way out.
    I have no idea why LR went to such extreme measures to secure the bolts.
    D1s & RRC just had regular Nylocks IIRC & they were never a problem.
