Results 1 to 6 of 6
Thread: Rear Diff Center Removal
    Mar 2009
    Near Geelong, Vic.
    Following my rear axle saga:
    http://www.aulro.com/afvb/series-ii-...ratio-rwd.html
    I need to remove the rear diff centre.
    Any tips?
    I have a couple of dodgy vertebrae so I have to be cautious. Sideways lifting is out. I was thinking of easing it off onto a board on my well padded gut.
    It looks horribly over-engineered! Will disembowel myself?
    Narre Warren South
    Haven't done it from underneath but at the beginning of this video it shows you one being removed [ame="http://www.youtube.com/watch?v=ytN3yTYzBr8"]Land Rover 90 - DIFFERENTIAL REPLACEMENT - YouTube[/ame]
    There is a flat face on the diff centre with a couple of tapped holes (usually full up with dirt) I've often wondered if these were for fitting/removal. Maybe bolt it to a plate which than mounts on a jack.
    Probably just a convenient way of holding them while setting up the backlash etc.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    May 2013
    Bittern Vic
    The gut method sounds good, you will need to get the car to the right height to be able to slide under it.
    The nuts holding the diff centre may be whitworth if you have trouble getting a socket to fit.
    Mar 2009
    Near Geelong, Vic.
    BadBack=BrainsB4Brawn
    Here is my take on Ikea assembly instructions.
    Sorry a few photos are blurred- there was a blob of oil on the lens.
    Yes, the welding is appalling but I was forced to use my Blind Freddy Welding Helmet for the 1st time in 15 years.
    Reactomatic Welding Helmets
    And hey, nothing broke!
    Mar 2009
    Near Geelong, Vic.
    Part 2
    COWABUNGA!
    Now! I HOPE I can get a thin screw driver between the planetary gear to knock out the broken axle stub.
    Dec 2009
    Queensland (though occasionally elsewhere)
    I'm impressed with your little cradle for removing and lowering the diff, whatever the state of the welds.
    When I pulled mine out, I just reefed it out on top of me, screaming "Auuuuurrrrgggghhhhhh!".
    Mind you, that works as well.
