 Originally Posted by
nivekau
				To remove the air pipes from the air drier, press on the red and blue collets with a suitably sized spanner and pull the pipe out, it should come out quite easily.
I ended up ordering
this kit from ebay
 I have previously had to take my compressor out to replace the bracket and the hardest part I found was to take the input pipes out.  In fact would not come out at all and I had to cut the plastic tube the get the compressor out.  When it went back in I just used a piece of rubber fuel hose as a joiner.
Is my compressor still works Ok but did through up a fault the other day I was going to replace it with an AMK but they are still a bit expensive so I bought one of the kits you bought which arrived Monday.  As my compressor still works and the kit basically re- rings the piston as well as providing the gel etc so I think it brings a working compressor back to "like new".
It only took 10 days and if you scroll down in the ebay ad they have a very good instructional video on how to do the whole job.
