RAI isn't water sealed. A Snorkel is...
You could seal it; just take your time...
 Master
						Subscriber
						Master
						Subscriberhi guys
I am going to get a Raised air intake. which I am thinking of installing myselfI also want to add a uhf antenna to the side of the roofrack ( with fold down bracket if I can find one to fit), and also a light bar at the front.
can I run the cables up inside the rai? or would I affect waterproofing and would they make a noise? I am just concerned about taking off the trim on the windscreen pillar in case it doesn't go back with two cables in there.
thanks
Simon
Just to add...
Yes you can cable inside, or on a Disco/RRS you could go up behind the A pillar trim.
 Master
						Subscriber
						Master
						Subscriberthanks I had read that it was not watertight but I thought LR had made improvements to it? if not I guess I can search to see how others have achieved this
 Master
						Master
						Simon i got my LR RAI installed by Opposite Lock who sealed it between the RAI/Body/intake and the airbox itself, required changes to the the hoses as they are only air rated. The LR dealership would not do this, they would only fit it as a standard RAI. All up including LR RAI, fitting and sealing it cost me approx $1750, trouble is every time its serviced and the air filter is changed, its not sealed anymore, i have been told a slop of vaseline should sort it next time i go wading
Or Opposite Lock will install a Safari snorkel for about $1000 less than that....
Mark
2003 D2a TD5...gone...
2000 D2 V8...gone...
https://bymark.photography
 Master
						Master
						Mark
 Master
						Master
						not sure what he drives Mark, just providing some facts in regard to my route as they say and what it cost.. If he has a Disco, then why not go the Safari route... a bit uglier yes.. but practical
