Results 1 to 10 of 17
Thread: td5 hard starting issue
    May 2009
    wimmera
    having starting issues with my d2a where i am having to prime the fuel system to get it started.
    nanocom is showing no codes and reads rpm when cranking
    there is very little cat noise when priming
    but willcrank and crank with no life like it has no fuel, prime the system and it normaly starts first kick.
    its only done 2000km since the filter was changed
    it has also been running rough at high load at low rpm and lacking power.
    iam thinking its the fuel pump any other possibility's
    does the the td5 have an inline fuel pressure regulator to hold rail pressure and do they fail?
    thanks
    mark
    May 2008
    Lismore, NSW
    Can't help with your problem but the TD5 has a FPR and they can leak. In my experience this didn't prevent the vehicle starting or running, but did use more fuel as it leaked out.
    Have you checked the fuel hose near the tank where it runs over the chassis?
    I believe they can rub through. If this happens you could be getting air into the system.
    Warren
    Currently Landroverless - Still interested
    Formerly: 2003 D2a Update TD5 Auto. Platinum edition. ARB Bar, 36" LED light bar, cargo barrier, dual batteries.
    Oct 2008
    bacchus marsh
    Replace the air bleed valve at the fuel filter
    Had the same problem on my defa td5 110
    Hope it works for you
    Aug 2014
    California
    Check fuel pump, injector seals and copper washers.
    Sep 2010
    The Hills.
    152.79 MB
    Mine had the FPR leak. Never caused it to not start, but was slow. Minor leak. Since I fixed it it starts instantly, hot or cold. Well, instantly after I press the unlock button on the fob. Never used to need to do that. I blame Adrian. Lol.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by lyonsy View Post
    h
    thanks
    mark
    Yes. It's under the inlet manifold.
    Here is a useful link: www.discovery2.co.uk / Workshop / Fuel Pressure Regulator
    Williams West Aust
    I had the same issue with my D2 TD5.I replaced the air bleed valve just before selling it.There was some improvement,but I was unsure if the issue was resolved.
    I did buy a new fuel pressure reg of Ebay that went with the vehicle,probably the root issue.
    Search Ebay,you can buy the seperate regulator and fitting kit,MUCH cheaper than a OEM FPR.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    Sep 2010
    The Hills.
    152.79 MB
    I
    Andrew
    That's where mine came from. Came with everything. Cheap as.
    Moruya Heads/Sth. Coast, NSW
    thanks
    mark
    You may have to replace the "O" rings and copper washer seals on the Fuel Injectors, when they leak you end up with air bubbles in the injector, causing your symptoms, Regards Frank.
    May 2014
    Point Cook, VIC
    Had same symptoms which turned out to be the injector washers. Took me less than an hour of research to find the solution, four days to convince the diesel injection servicing workshop to stop trying to find other causes and just replace the washers.
    But also had most of the other potential causes as well at different points in time.....fuel pump, fuel pressure regulator, bleed valve, cracked fuel line.....so if they have not failed yet it is only a matter of time.
