Results 1 to 8 of 8
Thread: Help Nanocom
    Dec 2010
    Mirboo North Victoria
    Help Nanocom
    Hello fellow P38r's my BECM unit has died and i am installing a Mobi-lize unit to repair computer security fault the instructions state i need to do a security re-learn to ge things going (After the GEMS has been introduced to the MOB-LIZE with a security code re-learn the MOBI-LIZE sends a coded bit stream directly to the GEMS regardless of what state the BECM is in.) is there anyone close handy to me that can perform this rel-earn i am willing to pay fuel/costs if someone can help. I hope to take delivery of the Mobi=lize tomorrow Postal service willing and envisage it being installed by tomorrow evening. Any help/ advice appreciated .
    Gippy
    Feb 2013
    Gosford, NSW, Australia
    Mate
    I am a bit far away sadly
    You could have a look here
    http://www.aulro.com/afvb/electronic...ostic-systems/
    Steve
    Dec 2010
    I have found help will all be sorted Sunday
    Feb 2012
    Carnegie
    What's Mobilize?
    Feb 2012
    Carnegie
    Arh - yes - Labtronics by-pass thingy. A wise move. Must get myself one of those when the shekels allow. Let me know how you go with it.
    What's involved with a security re-learn?
    Blairgowrie, Vic
    Relearn.
    Plug in Nano - find appropriate section - instruct ECU/BCM to relearn security code.
    V simple.
    Pete
    Dizzie, 08 D3 TDV6 SE
    Feb 2012
    Carnegie
    Have to get me one of those there nano's as well.
    Dec 2010
    I have a guy coming to do the re-learn for me on Sunday the Mobi-lize is a computer bypass that gives the GEMS computer a new security code and will keep the BECM running for a while longer apparently they are getting
    Alzheimer's as they get older and forget the security code so go into shut down not what i want up the bush. The Mobi-lize reintroduces a new code and bypasses the faulty code in the BECM there is also a get home get out of jail type wiring setup that can be fitted to get you home even if the BECM is dead or drowned so i will be wiring that in too. It requires some jumper wiring to be put in and only used in absolute last resort type circumstances it will get the car going and hopefully be able to drive home.
    Time will tell Gippy
