The above is not quite accurate. Early heads, which cannot support significant shaving were 7:1. Later heads are identified by a square boss on top between the rockerre cover and the carburetter. This should be stamped with the original compression ratio, either 7 or 8.
Unfortunately, there is no easy way of being certain whether it has been skimmed since manufacture, but either will stand increasing up to about 9:1 or even higher, although above 8 the engine may become intolerant of everyday fuel.
The only certain way of determining the present ratio is to measure the current combustion chamber capacity by filling it with a measured quantity of liquid (upside down on bench), including any space in the cylinder above piston, and taking the ratio of this the the cylinder displacement. This will also allow calculation of the amount to skim to increase the ratio by the desired amount.
