Results 1 to 10 of 37
Thread: 12V setup for camper trailer.
    St Helena,Melbourne
    4.28 MB
    So now that the weathers improving i need to think about adding power to the camper, i looking for a fairly basic 12V setup for mainly powering a fridge and LED lighting plus the odd charging of phones, laptop etc.
    I dont want 240V wiring but do have a 400W inverter for those times when the wife wants to use a hairdryer or even a kettle.
    For starters will be using a 100 AH deep cycle with provision for adding a 2nd with re charging via a folding solar panel and via the cars D/B system.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Aug 2010
    Sunbury, VIC
    A 400 watt inverter won't run a hair dryer or kettle. A 2000 watt version barely would, and if you go to something that big, remember they will draw nearly 170 amps at 12 volts when running at full load like they would be if your running a kettle or hair drier. That would flatten your battery in short order if you only have 100AH to play with.
    Tell your other half to leave those things at home and stick with the 400 watt unit. You will need a 35 to 40 amp supply for that.
    Apart from that a 100AH deep cycle and a 120 watt solar panel will run your fridge, lighting and chargers fine - that's what I have and I never go short on power.
    St Helena,Melbourne
    4.28 MB
    Hairdryer and kettle aside, what should i be starting with ? Some kind of switch panel with circuit breaker and a couple of fused cigi and USB sockets in 2 locations.
    1974 VW Kombi bus
    Doc130 Guest
    12v setups depend on what sort of camping and for how long you want to go being self sufficient. These things depict battery sizes, solar panel etc
    Aug 2010
    Sunbury, VIC
    Yep, that's a good start. As pretty much everything these days charges off a USB outlet, make sure you have plenty so everyone's not fighting over them. 2 in each location at least. If you're not up to making your own panel up, there are some good ones on the market that are as easy as wiring them to your battery. Mount the reg for your solar panel close to the battery - don't leave it on the panel. Have a set of connectors to hook your solar up in an easy to get to location that gives you some flexibility in where you can place your panel - on either side of your trailer. If your trailer has a flat surface on top of it, design it so the solar panel stores there and stays connected to the battery - it will always be fully charged when you head out.
    Aug 2010
    Sunbury, VIC
    Quote Originally Posted by Doc130 View Post
    Very true. As an example I run a 120 watt panel, and a single 100 AH deep cycle battery. I run a 38 litre a Engel fridge and 2 strips of LED lights mainly. A small 12 volt pressure pump for water and a big floodlight (27 watt LED) which I use when setting up in the dark, or if there is a need for lots of light.
    I can go away almost indefinitely with this setup. Even without the solar panel hooked up I can go 3 days just off the battery. My limiting factor is my fuel bill, not the amount of power I have.
    Doc130 Guest
    Bicicat, to be honest I doubt you could camp indefinatley with that setup. Fair enough saying you can go three days without charge but if we really want to get all technical about 12v, without doing the calculations I would say you would have the battery well under 50% charge after three days which is not exactly what deep cycle batteries like. To give the ultimate setup for battery life you never want to let your deep cycle battery go below 50% charge at any point, ever! However, not many people think of this when designing their 12v system. Not knocking your setup at all coz it would work great, just thought it is worth mentioning. Personally when I think of indefinatley, you want to be able to go a week without sun or any sort of charge. This should cover almost all situations, if it was raining for that long I'm sure that you would probably pack it up and move on.
    Aug 2010
    Sunbury, VIC
    Been out in it for weeks straight - never had an issue. Stayed in one spot many nights in a row - no issue. You are right about running it 3 days straight without charging it - it drags the battery down, and it isn't great for it - I only did it that time because I forgot my solar panel... That won't happen again as it permanently mounted now - not ideal, but still works fine.
    Oh, and when I'm home from trips, I sometimes forget to plug the fridge back into 240 volts and just leave it on this system and I've had it go over a month and still had a couple of beers in there at zero degrees when I remembered to plug it in and the battery sitting on 12.7 volts - that was just recently coming out of a Victorian Winter. That's pretty much indefinitely in my book.
    Oh, and I'm a Sparky by trade who specialises in DC control systems so I sort of understand what I'm up against.
    Doc130 Guest
    Maybe in a Victorian winter, it must be close to zero anyway, but anywhere where the ambient temp is even above 25 degrees I don't believe you could run a engel fridge especially, for one month and on a 100ah battery and still have 12.7 volts. Engels aren't as good on current draw as people think. I've got a shunt setup which doesn't lie. I've run A few mates Engels of varying sizes for a test and my nation luna. Luna wins hands down!
    Queensland
    First off, hi Doc and not taking a deep cycle battery below 50% is a myth.
    All deep cycle batteries have always been able to be discharged down to 30% but all modern deep cycle batteries can be safely discharged down to 20%.
    Hi Loanrangie, can you tell us more about your set up and intended usage?
    What size solar panel do you plan to get or already have?
    What sort of set up do you have in your tow vehicle?
    Are you planning to set up in one spot and stay there or to move regularly from one spot to another or set up in one spot but do lots of day driving?
    All this and any other info you have will help you to set up to meet your specific needs.
