30th September 2014, 04:31 PM
Rim wanted for no 5 trailer
I am looking for a rim for my no 5 trailer to use as a spare wheel. I am looking for part No. AYG8108 which is the 6.0x16 size. I realize this may not be the original rim size that was issued but it's what's on there now. It's the rim with the circular raised bit for the wheelnuts.
I tried TRS but they had none saying I must have the wrong size, it must be either 5, or 5.5 but it definitely has ROH, 6x16 stamped on there along with the part no AYG8108
Somewhere in Adelaide would be great if possible. Thanks
I just realized this should be in wanted to buy, Mr Moderator??
30th September 2014, 04:38 PM
Can't help you there, but just to clarify, the Perenties have a non-standard 6" rim and all the No5 were retrofitted with the 6" rims to correct the track a little and be compatible with the Perenties.
You need to find someone who wants to use the No.5 behind an SIIa or SIII.
Be aware that the SIII had a similar ridge around the PCD as the 6" rims on your trailer, but were only 51/2"
