A old mate of mine who is a Caterpillar trained mechanic, hates silicon when it is used instead of gaskets, as he has seen lumps of silicon blocking oil ways and pickup's causing some very expensive damage.
My idea is, with a bit of care as you apply it and by tapering the wet silicon from a little at the inside edge to thicker on the outer side of the joint.
On assembly the amount of silicon that is then displaced towards the inside is then minimal.
