Results 1 to 4 of 4
Thread: OziExplorer users (particularly in NSW)
    May 2002
    Heathcote (in "The Shire")
    For those that use OziExplorer a download from this site
    http://sourceforge.net/projects/maprequest/
    will enable you to download maps and create the .map file from the NSW LPI site.
    <span style="color:blue">Example from the Snowball Sheet (Bendethra)</span>
    The maps don't have any grid so are really only applicable in a mapping program
    Its a bit fiddly (esp if not very computer literate) and requires you to have java installed on your computer (available here)
    http://java.sun.com/j2se/1.4.2/download.html
    with a bit of fiddling you can get very acceptable resolution maps of any part of NSW with the latest data.
    For our Qld counterparts there is a link to some qld mapping but I've had a look at it and quite frankly its crap (I looked at the area around Caboolture).
    Bushie
    Jul 2003
    G'day Bushie,
    I've tried to access the NSW LPI site with maps:
    http://maps.nsw.gov.au/
    No luck. Appears that there has been some bureaucratic shuffling
    Do you a have current link?
    Mahn England
    Ex 300Tdi Disco:
    Sydney Australia
    May 2002
    Originally posted by one_iota
    G'day Bushie,
    Mahn,
    That link still works OK for me - It takes you to a disclaimer page first.
    http://maps.nsw.gov.au/viewer.htm should take you straight in.
    The maprequest app allows you to download multiple windows from the server and assembels them as a single page (or something like that) the end result is you end up with a map you can use in Ozi.
    Bushie
