Results 1 to 10 of 13
Thread: How to remove stubborn tapered shaft
    SW of Geelong
    I'm having trouble removing a timing surround from a small engine which is on a tapered shaft with a key.
    I've tried using a puller as in the picture, but I can't put too much pressure on it as it bends the component.
    I've tried soaking the shaft in WD40 for days, and I've just tried heat in conjunction with the puller, but no luck.
    I've also tried tapping the end of the puller with a hammer, but the threaded shaft is quite small, so I don't want to damage it by bashing the crap out of it.
    Does anyone have any suggestions ????
    Cheers, Murray
    '88 County Isuzu 4Bd1 Turbo Intercooled, '96 Defender 130 CC VNT
    '85 Isuzu 120 Trayback, '72 SIIA SWB Diesel Soft Top
    '56 SI Ute Cab
    Dec 2008
    Geelong
    WD 40 is basically only fish oil, have you tried Penetrol or anything similar? Might get in better. Keeping the pressure on and repeated side impact is th only thing that I can think of after the heat you have already applied.
    Oct 2012
    FNQ
    Is that a thread in the hub you could use that as part of a pusher if so
    AM
    Safety Bay
    Lots of pressure on the puller,some heat and wollop the end of the puller thread straight on with a hammer. Pat
    Can you fit the whole lot in a chest freezer overnight and then use heat in the morning?
    Dec 2008
    Geelong
    Quote Originally Posted by PAT303 View Post
    Don't hit the end of the threads directly, turn a nut on till its above the end of the shaft and hit it to protect the threads.
    If it will fit to give a little clearance , put the nut back on , high enough to clear the puller shaft as in not contact with the puller shaft so`s to protect the thread .
    Do the puller up as much as possible .
    Lift the whole lot into the air so`s it clears the bench .
    Hold it by the puller and hit the puller shaft with a hammer sharply . Use gravity .
    If mine i would do the puller up and tap the screws to judge the tension lift it belt it till it parted then repair the thread if needed .
    You may know , the correct puller screws into the large thread inside the flywheel close to the shaft .
    May 2006
    Southern Wimmera.Grampians
    Ancient mariner is onto it. You need a puller that uses the internal thread of the fly wheel, tension up tap with hammer all good.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    looks like stainless timing surround?
    if you use the internal thread (my recommendation as well) use plenty of antiseize on the thread and a bit on the shaft when you reassemble.
    maybe one of the generic hydraulic pullers will screw right into that...
    best of luck... some of them can be utter mongrels
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    SW of Geelong
    That's pretty much what I've tried, but I don't want to damage anything by applying excessive wollop
    Quote Originally Posted by Ancient Mariner View Post
    AM
    I don't have a puller to suit, but it might be worth trying a chainsaw repairer or similar. Using that big thread would be much better.
    Quote Originally Posted by incisor View Post
    looks like stainless timing surround?..........................
    Yep, everything on this machine is stainless or ally as it's fully submersed in salt water. It's an Aquascooter as in the pic, made in Italy, Bosch timing etc, all seems to be very well made. It's given us many years of fun and I'd like to give it a freshen up with some new rings, piston etc etc, and that means splitting the casing to remove the bore sleeve, but I can't do that without removing the stubborn timing gear.
    Cheers, Murray
    '56 SI Ute Cab
